Best way to use the iPad to read PDF, epub and mobi books
thanks for that Marilyn.
I've downloaded the kindle app but dont see how you can buy the kindle books?
:confused:I think I'm being dumb.
Stephen
Any recommendatory on the best Ipad solution would be appreciated.
Stephen
You're not being "dumb" - the rules were changed last year. Apple decide to press the issue and make any book seller pay the 30% in-app fee whenever someone bought a book through the iPad app. Amazon joined all the other book sellers/app makers and removed the ability to purchase books through the app. So, now you have to buy them by going to their web site (via browser).
You can still download purchased books (from your account) through the app. You just can't buy them.
The best solution is to buy your apps via the browser no matter which book store you get them from. Then, you can go into the applicable app and download the book for reading.
vj531 said:
Thanks again Marilyn
I read most books on my iPad's Kindle program. But I'd like to read some ePub books from my local library. I can't seem to download Adobe Digital ReADER (which it says I need). Any suggestions?
Double check with your library, but the best app to get to view public library books is the app Overdrive (free in the App Store). With a library card and an account, you can get virtually any library's books. You just need to make sure your library uses the Overdrive system (most do).
The app BlueFire Reader can also help you get and read library books.
They are both the same in that you have to authorize them with your Adobe Digital Editions password. But, once that is done, then you are good.
Hope this helps.
Hope this helps.
Thanks, Marilyn I actually have overdrive. There was an ebook I wanted to read that was on a different library system that did not transfer to Kindle (which mine does). That's why I needed ePUB.
Here is a free ebook conversion tool for you.
You can easily convert your ebook from pdf to epub.
It provides you with the best PDF to epub converting experience.
Thanks for your patience.:o
