HELP PLEASE Keynote problems
Bobsummit
France
I am trying to send a PDF or PPT file from Powerpoint, via email attachment, to Keynote. The instructions say just click on the icon and 'open with Keynote', but the Keynote option is not in the box. I have downloaded Keynote correctly but it doesn't seem to be recognised in the 'send t' box
Can anyone help with this
Cheers
Bob
This will only work if you use .ppt or .pptx format. Keynote cannot read a PDF format presentation.
Thank you Tim
will try that - somewhere I read that PDF would also work but clearlky that was wrong
Cheers
Bob
No - just .ppt and .pptx. It can, however, export in .pdf format, so maybe that's where the confusion came from...
Hi Tim
brilliant - just tried it and it worked perfectly
Thanks for your help
Bob
