Help with sound
The sound on my iPad works for YouTube and the iPod but the sound no longer works for games or any other app. I've checked all the settings, made sure the volume is on, but it doesn't play. It won't beep for notifications like email when that function is turned on. I could use any help or advice.
Double click so the multitasking tray opens on the bottom, swipe all the way to the left and check the volume rocker there.
Also go into general settings and make sure the setting for the switch above the psychical volum buttons aren't set to mute and that it's off..
I have done both. Sound won't work with apps except for audio on YouTube videos and iPod app. It won't even play on the CNN apps videos.
I've had this problem myself and this is what fixed it...
I performed both of those a couple of times and sound won't play with any game app. It will only play for YouTube or the iPod. It won't give me email alerts either. Not sure what to do next.
How have you got 'Settings', 'General', 'Sounds' set up? You can turn various sounds on and off there.
I've had a couple of times where my Time Warner app had no sound. What has fixed it is to go into Settings, General, and change the Side Switch assignment from Lock Rotation to Mute. Then I slide the Side Switch to turn off Mute. For whatever reason, the sound returns. I can then change the setting to lock rotation, and the sound still works.
Dude, thanks. This was the fix. Awesome!
iPad sound will not work with games
I have done everything in this series of comments ... and nothing is making the sounds for the games work. I am at a loss at what to do next!
UPDATE:
Just solved it via another post in the forum... above the volume switch on the side of the iPad is another little button that puts the iPad in MUTE mode ... just like on your iPhone ... switch that back and your volume is ON ... YAY!
Thanks! I have had the original Ipad for over a year and you just fixed my problem. I had no idea I had it on mute, I guess I
should read all the instruction book. :)
dude....even it worked for me....awesome...i was really fed up with those apps with out sound....its a simple thing but amazing....
thank you very much
UPDATE:
I had the same problem...thanks.
