As I needed something for a trip coming up (both to play movies and to copy photos to from my phone) I picked up the Seagate Wireless drive. At 1 TB, I can put all my movies (at this time) on it (690GB) and have room for the photos.
Using firewire 800 on my Mini, I copied all the movies over and it took just 2 hours and change. Nice. I upgraded the firmware and then set about to checking out how it worked. I was able to play different formats (SD and HD) with no problem. Since all of my movies are in iTunes anyway, I had no issue with file format. I also tried playing movies I purchased in iTunes. As my iPad is synched to iTunes, it worked how the site said it would; it used Safari and the quality was as good as if using the native player. Next, I took some photos with my iPhone and proceded to copy them to the device with no issue. It created a folder on the drive with the iPhone's name on it and put the photos in a Photos folder under it. It was also viewable from my iPad as well and can be copied then to the Camera Roll for editing. Thinking huge sharing capability here, lots going on in my head on this one... I also decided to see how the throughput was and watched a movie on the iPad while copying more photos to the drive from the iPhone. No skipping whatsoever.
I already have a Zagg Spark3, so I have plenty of juice for the drive just in case. I like the design of this drive, and I think the capabilities will fall right in line with my expectations. It also plays nice with other wifi networks - allowing you to first connect to it, then piggyback off and connect to another wifi network for internet. works well, and I had no issues connecting to my home wifi after connecting to the drive.
Man, the ability to share photos and copy them up. I have the Camera Kit, and can see shooting the day away with my DSLR and then copying them to the iPad via kit then to the drive and clearing my iPad. Yep, lots of ideas coming. Can do the same with my GoPro!
Say what you will on Seagate, the drive comes with a 3 year warranty. I dont expect it to be a backup or only copy drive. It will be a working drive. And no, I dont sell computer equipment in any way. Just giving my day-one quick review.
