HP Wireless printer ... how to print from iPad?
Step to print from ipad
Make sure you have the Pages app installed on your iPad.
Connect the iPad to your computer using the appropriate USB cable.
Open iTunes, then locate your iPad in the source list and select the Apps tab. Scroll down to access the File Sharing Pane.
The File Sharing Pane is a centralized location where you can manage the transfer of documents to and from your iPad. To print, transfer the desired document from the iPad to the Mac's hard drive. Then simply open and print using a device connected to that Mac or a device on the Mac's network.
Alternatively, e-mail yourself any documents you want to print, then open them on a Mac with printer access and print from there.
I am able to print from my iPad on my WiFi network on Printopia. Easy as anything just downloaded the demo onto my Mac and it worked great. They give a free 7 day trial, my printer is an HP 6400 series. If you like the software it is only $10 and will also print from your iPhone 4.
All I had to do was hit print.
I was surprised that I didn't have to set up anything on our new HP Officejet 6500A to print from iPad. My husband bought the HP as a cheap stopgap while we were moving from another state and our normal printer was on its way. We weren't even planning to print anything from our iPads. I just hit print to see if anything would come out, and it did, lol.
Q: I am probably notposting this correctly, but if I have a wireless AIO brother printer will the pages App help me be able to communicate with my network? Any suggestion woukd be greatly appreciated. It took me 3 hours to remove my encryption and get the printer hooked up with my network - which was huge for me btw
Is this something so easy, I should be ashamed? I tried to print an email from my mail app and it will not even populate my router network - probably something or sme things I fail to understand.
Any comments - even mean ones would be appreciated. My 10 year old thinks I can't print from this ipad2 but certainly - i should be able too.
Alex
Wi-Fi
I have a HP LaserJet P1102w printer and a new iPad. I can print to the printer wirelessly if I disconnect from our 'Wireless Access Point' and connect to HP Printer via Wi-Fi and then go to 'Printer'. Then I see the printer and print to it.
Is there a way to connect to it via wireless through the printer option and not have to disconnect from our 'Wireless Access Point'?
It would be nice to stay connected to the internet through the 'Wireless Access Point' and to HP Printer at the same time.
I would appreciate any comments or ideas.
In print, and wireless technology is beginning to become a new trend in the industry. DESKJET 3000 is one of the best wireless printers, HP is proud because of its price in the hand. I am able to print from my iPad on my WiFi network using Printopia.
