I Tunes problem
Im having a sort of similar problem..I can get the app store up no problem, but I was in the "genius" section looking at similar apps I had downloaded and that feature just quit on me. I can access the categories, top charts, etc, but the genius part gives me "cannot connect to Itunes store".
Any suggestions? I did try the above and it didn't work.
You'll probably have seen from other posts that the App Store has been having 'issues' ('problems'!) recently. Concencus seems to be that they're upgrading it - perhaps for the arrival of the iPad2 and the new apps for that machine.
I sometimes get that 'cannot connect' message too, even though everything else works just fine. I usually leave it for a while and come back a couple of hours later and the problem has gone away.
Thanks, Tim, I will just keep waiting...but I was hoping it was the store and not me..
OK - if the problem persists, get back in touch and we'll suggest some more possibilities. Being in the UK, I see the UK iTunes store, so it's difficult for me to check out whether the US store is currently 'up-and-running' but, since the iPad2 is out this Friday in the US (and not for another 2 weeks in the UK) I'm assuming that any modifications or upgrades they're carrying out are being implemented in the US first of all.
