I have an iPad 2 that has a problem with charging.
i hadn't used it for a while and then had a problem with it getting to charge and start up. But somehow by pressing the home and power button a number of times differently it started up and has been working perfectly. But I let the battery drop to under 10% the other day and now can't get the charge to get up above 5 %. The battery otherwise is fine and lasts a good amount of time.
i would really appreciate it if someone could give me some help as to help as to how to get the battery charging. I can't remember what I did exactly last time. If anyone has any idea as to what to do it would be great.
Its not not the cable or charger I think as it works fine the rest of the time, I bought a new charger, so it could possibly be the cable but that wouldn't explain why it works perfectly the rest of the time
i tried restarting it. And it has been charging all night but the battery is still 5%.
Many thanks
Many thanks
