iPad VGA and USB Camera Connection Kit
clayton93
Hi,
I was just wondering if anyone knew if it was possible to use a USB to VGA cable using the camera connection kit to connect the iPad to a display? I know there is a VGA adapter but if I only had to buy one of them that would be great.
Hi,
No - this is not possible. The camera connection kit can only be used for importing pictures and video. It cannot be used for exporting any files or other information on a non-jailbroken iPad. Although the CCK is supplied with a USB plug, it has limited functionality and can be used only to connect to your camera.
Ok thanks Tim. I would've thought not but I just wanted to be sure. Shame, I'll have to buy more than one of them.
