How did you get the pet to unlock cage behind the bookcase. The only two people you can use is the Wesley brothers?
You're in the Year 5 Weasley Storeroom, right? If so, you go into "pet" mode, which is actually a little black sneaky detonator (or something like that). Walk it over to the cage and tap the wand button and it will explode the cage, releasing what's inside.
I'm stuck at the beginning of year 6 the cave entrance. How do I get the cave to light up so I can see the platforms in the water I need to raise and jump to?
For all levels there are some things you can't do the first time through. You need certain characters to make certain things work.
As for me, I'm stuck in the final battle as Molly Weasley, trying to get Bellatrix. I have used reducto on the thing above Kingsley, but now there doesn't seem to be anything to do. I have been firing willy-hilly at everything, but nothing is happening....anyone else know what to do?
As ou have got this far can ou tell me how to get past the dragon in gringotts bank?
I can't get the last bit for the third table. I've got the middle and right piece- can anyone help??
Eta: did it with the pet. Now I'm stuck in the hall trying to get the broomstick. I can climb up with sticky trainers but get stuck at the top...
At the top you have to jump to the platform on the left with the broom. It's a tough jump, took me a few tries.
Stuck in the Burrow on Fire. Got the tube created but can't get the Lupin animagus to go up the tube and neither Arthur nor Tonks has a pet to send up there. Have put out the fires I could with the cart and not sure what else to do. Help!
Anyone having trouble in year 6 when trying to retrieve the goblets to drink the water in last level? I keep getting stuck behind one goblet and the brick won't activate for me to pick the goblet up.......And yes I have activated it with the deluminator.
I don't think you go up the tube until you go back in free play.
I am in year 6, the cave entrance and can't pull out the stairs after using the red circle. I have the handle, but neither of the characters I can use (Harry and Dumbledore) can pull it. What am I suppose to do? Thanks.
Use the deluminator to light the upper left globe, if I remember correctly that will allow you to pull the stairs out.
I!m stuck in the Wesley's shop in year 6. Got access to upstairs, I've put the powders back in the 3 jars, fed sweets to the dog, made the dog cry, hit the flying saucer! But can't figure out what to do next. I've been back downstairs but can't get out of the shop and have replayed the level 3 times but still can't figure out what to do. Can any one please help? Been stuck here for 2 days and it's driving me mad. Thanks
