I you mean when you are trying to get into the cave entrance there is a great post on page 14 of this forum post #131. It helped me. Also post #134 for the next part.
Switch to someone who has lumos. Use lumos to walk just a little ways and then there is a big glowing ball. You walk into that and then the area lights up. You have to do this in two different areas. If you are having trouble moving the lights with the deluminator later on, go to page 14 of this forum and look at posts #131 and 134. They give detailed instructions on level 6-4.
Did you move the stove (thing with burners)? You have to move it using the handle, grab on and pull it. It is somewhere on the left of the screen.
Go to page 14 of this forum and look at post #131. It gives detailed instruction. Also post #134 gives help on the next part.
Go to page 14 of this forum and look at post #131. It gives exact instructions. Also post #134 gives instructions for the next part.
Try using lumos with harry. Then walk a little ways and you see a glowing ball. Walk into the ball and the cave should light up. You have to do this in the next area also. Don't use Dumbledor and the deluminator use Harry and lumos.
Hey. So in the last chapter of DH2, I'm missing the very last character token. I've got everything else, so it's really just that.... Can annonce please help me?
I've seen this asked several times before but have not seen any answers: How do you get the final character token in the Legimency/Kings Cross section? I have the token Detector activated and can see it's Ghost on the platform but every time I proceed into that part of the platform, Voldemort appears and the section automatically ends.
Devils Snare help
So I'm in year Six and trying to ind Harry in the field after the Burrow's fire. I can't seem to get passed the Devils snare. Typically I can use lumos, that is what is recomended, but no matter howany times I shot nothing happens. On any other level usually a single brick pops up to touch. Nothing here. I've been stuck for a day now and need help!!! Also, I can't go back to Hogwarts. I'm literally stuck on this level. Any help would be great!! Thnx
Stuck for week. Need help please. I am in year six and can't get the third key (need to get the statue head located behind the green vine), but I can't reach the vine to make it melt away. There is also a lamp next to the plant, but I have no deluminator as of yet. I can't figure out what to do. This is the room where you learn augmente and you pump up the water hose for the guy in the picture.
