Lost keyboard on ipad 2 , very slow after iso7. I am not a techno so need help please
Since i have updated to iso7 I have lost the keyboard in a funny way , I type the words and it thitydsdtoctc sorry it takes the keyboard amin or so to catch up I am typ th. YOU CAN see the problem i am havingd
If you have not done so after the update try restarting your iPad. My devices always seem a bit lagged and unpredictable until I do.
The usual fixes:
Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
