printing to a wired /wireless printer
thosman
philadelphia pa.
I have an ipad2 with print n share app loaded. I have a wifi printer that hooked up to my computer by usb. i have a wireless router hooked to the computer. Im not sure if i have to enter something into the ipad such as a setting eg. or on my printer .if this makes any sense can anyone help me? im not sure how to end this thread or say that problem is solved
You need to install their software on your computer that the printer connects to and you need to have that computer on when you want to print.
From their website http://mobile.eurosmartz.com/products/printnsharepro.html
Print n Share Pro will print direct to most WiFi printers, or to ALL printers (Bluetooth, USB, WiFI, Network) via your Mac/PC using the free WePrint software. If WePrint is required on your Mac or PC you will not need to touch or be near your computer to print, you simply tap print on your iPad, iPhone or iPod Touch and the computer will act as a relay and automatically pass the print job from your device onto your printer without user intervention
