Problem with ipad 2
Jimmy22
I cracked my iPads glass last week and I just replaced it to day however I can not hit the lock button to get to the lock
screen I enabled assisted touch and it to does not get me to the lock screen I tried holding the lock button and it works For shutting down my iPad I also have a smart case which is suppose to lock my iPad but doesn't no I have to Waite 2 minuets for my iPad to fall asleep which is the only way it locks please help.
Hello there Jimmy
This here is for new members that want to introduce themselves to the forum. You should be able to get better assistance in another area of the forum. Sorry buddy.
I cracked my iPads glass last week and I just replaced it to day however I can not hit the lock button to get to the lock screen I enabled assisted touch and it to does not get me to the lock screen I tried holding the lock button and it works For shutting down my iPad I also have a smart case which is suppose to lock my iPad but doesn't no I have to Waite 2 minuets for my iPad to fall asleep which is the only way it locks please help.
Hi, Jimmy! Welcome to iPF!
First try the usual fixes:
Restart: turn off your ipad, wait for a few minutes and turn it on again.
Reset: press and hold Home and Power button simultaneously until the Apple logo appears. Then release both and let the iPad power up on it's own.
I'm not familiar with screen repairs, but maybe this will help: somewhere I read that this can happen when there's a bad solder joint on the home flex. If this is the case, the Power button won't work, and the screen won't be locked by a smart case.
Hope that helps.
Hi Jimmy and welcome to the Forum!
Did you replace your screen yourself? The only way we can really help is with the info that JA has already given you. I've heard of this and other problems occurring from members trying to fix their iPads themselves, something else is damaged in the process also.
We always recommend making an appointment with Apple, they normally offer to replace your iPad but for a cost which is normally half of what you would have paid for it.
You could always try them now and see what they say to you.....it may be worth a try.
I will transfer your thread to our Help Forum in the hope that someone here may know more about your problem. Good luck!
Tutorial for our App
http://www.ipadforums.net/new-membe...sistance/107524-ipad-forums-app-tutorial.html
Tutorial on creating posts on the Forum
