problem with safari
fagani
hi
just got a problem with safari
i download a website (no problem with that) but when i try to enter the content of the web page it is impossible: the page is grey and when I tap on the screen nothing happens
this is only with safari
any help?
thanks/Fabio
It could well be that the website is using something for input which is not iPad compatible, e.g. flash, activex, java, etc.
It would help if you could tell us the site.
it is for every site, like google for example
Well that's not normal behaviour at all. Try a full reboot, which normally solves little problems like that. Hold the power button until the slide to turn off slider appears, then slide it. Wait till the iPad turns off, then turn it on again. Hopefully it will be OK after this.
Safari works fine for the vast majority of sites under normal operation, but especially google etc. I suspect something has hung somewhere and needs to be cleared on your device.
now it works again
thanks a lot mate
