Problems using handbrake to rip DVDs for my ipad
nicw70
Hello
I have an original version ipad and have been told about using Handbrake to convert DVDs to save to my itunes and play on it. This a brilliant program, but I seem to have problems with certain DVDs. Some convert perfectly and play perfectly and others completely pixilate when they are converted. Is there something I need to change in my setting to get Handbrake to work when converting all DVDs?
Thanks in advance!
I had the same difficulties ripping two DVDs for my daughter. My solution was to first rip the discs through DVD Decrypter and then through Handbrake. Obviously the former strips all the copy protection (or whatever). Took forever to go through HB, but turned out sweet!
I found a decrypter that I got a free trial for for 21 days and it worked a treat.
Thanks!
