Remote desktop connection and volume
Ipad24meandu
Hey All,
I have been searching the postings for some insight about rdc's and I have not yet found anything specific to my question. My current rdc client allows me to connect to my home computer and it even allows me to watch the movies on my iPad. However, I cannot get any volume through my ipad. I would love to actually enjoy the entire movie experience, especially with volume.
Has anyone successfully used rdc to watch movies AND been able to hear the movie they were watching? If so, what client are you using and did you have to configure your client appropriately?
Any information would be most appreciated.
Thanks all
Splashtop works just fine and, yes, the audio is transferred from your PC to your iPad too. There's a Lite version that you can try (5 minutes viewing time) that's free, so that you can see if it works for you. Setup is a breeze; there's a free desktop PC app that needs to be loaded and running in the background and, of course, your PC needs to have WiFi - but that's it.
Sounds good. I'll definitely try it out. Thank you for the help Tim!
I have been using Mocha Remote Desktop for months and I am extremely happy with it. Very easy to use as well, though it's pretty expensive if you decided to get it from the app store. It is lite version.....
I have been using Mocha Remote Desktop for months. I am extremely happy with it. Pretty awesome app, very easy to use as well, though it's pretty expensive if you decided to get it from the app store. It is Lite version....
