Safari problems
Safari now unfrozen!
Just do a reset home button and off key until white apple logo appears. It may be another app causing issue.
This worked!!! Thanks!!!
Problem solved
Thanks for Sarah's advice; pressing the both function keys until the Apple showed up solved this for me. The gray screen is gone and Safari is back up and running.:)
This has been determined to be a bug in Safari.
Go to Settings
Select Safari
Select AutoFill
Turn it OFF
Close Settings
Reopen Settings
Join your network.
You can turn AutoFill back on now if you want but if you connect to some other network and then come back to this one it won't connect while AutoFill is turned on.
Apple will fix this in an update.
old info but it worked on my iPAD Mini. thanks!
