Splashy
I have an iPad 4 the wifi version and a Galaxy S3.
I'm using the S3 for wifi tethering for the ipad and I'm experiencing very slow speeds and connection drops.
I don't think it's a problem with my carrier because I did a speedtest on the Galaxy and the speeds were great, however the speeds on the ipad when tethered to the Galaxy were very slow but on my wifi home connection everything works great and the speeds are much better on the iPad.
I was told in another forum that it might be a problem or incompatibility with the combination of the Galaxy with the iPad.
Would the iPad work better with a portable hotspot device such as webbing spot or connect one for example (These are available in my country)?
I would like to know what you think, if I could get significantly better speeds with the portable hotspot than what I get with the Galaxy.
Thank you in advance for your help.
