Sound problem
wbonet
Anyone having problems with some app sound. I install zen pinball and the sound played once then stop working same for angry bird seasons. Does anyone now why this happened?
Hi and welcome to the Forum!
If you've checked your sound settings, mute button just above the volume control and it's not these, it could just be the apps playing up. When an app behaves strangely it is best to close it completely and then relaunch it. From the home screen do the four finger swipe up or double press the home button to reveal your multi task bar. These are all the apps that you have opened at one time. Long press the app until it jiggles and a red minus sign will appear above it. Press the minus sign, this will close the app, not delete it, now press the home button to return to your screen. It's also a good idea to close all these apps, as it helps the iPad run smoothly. Let us know how you go.
