twerppoet said:First, it might just be battery calibration........ It happens, even to Apple products.
My daughters iPad will not even switch on after she shut it down after she noticed it was dragging it's feet whilst in the AppStore. Will you please hop me?
h1611161 said:My daughters iPad will not even switch on after she shut it down after she noticed it was dragging it's feet whilst in the AppStore. Will you please hop me?
twerppoet said:First, put it on the charger for a while, just to make sure it's got a good charge. An hour should be more than enough.
Then, hold down the power and home button until the Apple logo appears, about 10 to 15 seconds. Let go and wait for it to reboot. This will take a few minutes, so be patient.
This is called a soft reset, and often works for problems that restarting won't cure.
Charge your iPad until it indicates %100. Then use it until it shuts down by itself. Watch some movies, play slide shows, whatever. This could take most of the day. After it shuts down by itself charge it to %100 again.
Now use as normal. If the battery is still giving you problems contact Apple Support. You may have a battery going bad. It happens, even to Apple products.
This will sound stupid but how do you close them ? I thought when you hit the home button they closed since it doesn't do true multi task
Mountainbikermark said:......, I saw this thread and immediately asked only to find the answer in another thread.
Maybe your iPad is just confused! It is still officially winter and you travel FROM Florida TO New England! I think you have things backwards!My iPad (new in Dec) has had great life( length of time before it depletes) this weekend I was in Boston...
