David79 said:I didn't even know there was yet another update, geesh I'll stick with 4.3.2 for awhile.
Harters said:My battery is definitely draining quicker since 4.3.3
I never used to have any over night drain, but now I loose about 3%!!!
Sent from my iPad 2 using iPF
f4780y said:I hate to point out the obvious here and I'm not trying to be smart, BUT, 3% drain overnight seems perfectly normal for an iPad under standard circumstances and configuration to me.
According to my calculations, assuming overnight is about 8 hours, that gives you 11 days of standby. Pretty good in my book, unless you are the type that always has all your services switched off completely.
I appreciate you think you were getting zero percent battery drain previously, and sometimes you can observe that if you iPad was fully (over) charged to 100% when you left it (it can stick for slightly longer than normal at 100% in common with any battery powered deceive of this type), but losing less than 1% in standby over a period of say 8 hours would be exceptional. It would equate to something like 33+ days standby. I don't recognise that as being the normal standby time you can expect from an iPad.
I do find it interesting that whenever a new version of iOS comes out there are always people who seem to observe what they consider to be additional drain. Perhaps it is more to do with observing the device more than before? I don' know.
Anyhoo, my advice would be don't be worried by this. It seems fine... I don't see any evidence anywhere that 4.3.3 has a battery drain issue.
Harters said:Thanks for the info, but no matter what my % is at the end of the day it is always the same in the morning. I have push etc off. Usually it will stay at 100% for over and hour after a full mains charge, but now it starts dropping quite quickly. Maybe the battery level is now more accurate?
I will keep an eye on it
f4780y said:Cool. And if you do have everything turned off when in standby (no push, wireless, 3G, etc,) you are supposed to be able to squeeze 720 hours of standby out of the battery according to Apple. However that is absolutely a theoretical maximum and you would have to leave it in standby (never turn it on once) to actually achieve it.
Out of interest, did you upgrade or restore iOS 4.3.3. I am of the opinion an upgrade can introduce something into the mix which was not there before, perhaps related to wireless..., but that's just a theory.
Try resetting your network connections (thus forgetting all your wifi) and see if that improves things. I've seen it benefit others.
Harters said:What I have noticed is that I can have quite a good signal, but as soon as I click on a link the signals drops right down low, pauses then seems to recover again.
f4780y said:Are you talking wifi, or 3G signal? Definitely sounds like you need to reset your network settings.
cemturc said:I closed every single app. I even turned the airplane mod on. While nill app working on task bar, I just kept sliding the screen (to keep the ipad alive), 1% of battery could last only 5 minutes.
What do you think?
Mine doesn't charge through my keyboard USB port. It may be Apple playing mind games with me. I'll keep an eye out and report back. I should has my new iPad 2 next week...this may all be moot.
Sent from my iPad 64 GB, WiFi, 3G using iPF
