Battery drain
has anyone else found that AFTER UPDATING TO THE LATEST OS THAT THE BATTERY DISCHARGES AT AN ASTOUNDING RATE?
Hello and welcome to the forum! :) First, did you 'Reset' the iPad after your iOS upgrade? If not, then directions below if not familiar w/ the process. Second, this has been a common question here, so a search my be helpful. And finally, google 'iOS 7 battery drain' and there will be plenty of hits discussing the problem, such as THIS ONE. Good luck and let us know your results & solutions - will likely help others. Dave
Reset - press & hold the 'Power' and 'Home' buttons simultaneously until the Apple logo appears - this may take a longer time, so have patience; the iPad will 're-boot' - NOTE that none of these maneuvers will alter your apps, files, or settings.
HI--
Your other post that you have was deleted. Please do not duplicate posts since it makes it confusing to follow when there are multiple posts that are the same. It is also against forum rules.
Thanks,
Ski
Not really a few users have issues however it depends on how they use the phone. The same applies android smart phones
