Wingr
The JBM 3.0 jailbreak seemed so simple, I finally decided to JB my iPad 1 64gb 3g. It went very smooth and I am really enjoying the freedom and capabilities with a bunch of Cydia apps. I ran into one big problem though. The CCK doesn't work anymore. For 3 days, I've been hearing that it is going to be fixed shortly. This hasn't happened yet, and being a photographer, I really need it to work. My Eye-Fi card and ShutterSnitch work fine, but I also need the CCK.
These are the apps I'm using so far without issue;
iFile, Winterboard with MT Gestures, Backgrounder, Browser Changer, FullForce, Mobile Terminal, SBSettings, Netatalk, VLC Media Player and Unfolder.
Does anyone think the CCK can be fixed in JBM 3.0?
I'm considering purchasing the full iFile and pkgbackup if I'm going to stick with the freedom of a jailbreak.
If I purchase the pkgbackup, will I be able to restore without an issue if I have to switch to a different JB method because of the CCK issue?
I need the CCK working before next weekend. Would you recommend restoring in iTunes with my pre-JB backup and using the redsnow 3.4.4 untethered JB and if I do, should a pkgbackup restore work from a backup of the JBM 3.0 I have?
Is there a different JB untethered method I should consider? I use both Mac and Win7.
TIA!
TIA!
