glassheart
- Joined
- Oct 9, 2011
- Messages
- 44
- Reaction score
- 1
hi, i have ipad 2 wifi + 3g that has been jailbroken. My problem at first is that the apn settings the tab itself on the celluar data is missing so i can't add or edit apn settings... so what i did is that i went to settings then general then reset then click on reset all settings for the thinking i may have it back... the problem now is that i can't use my device because it restarted then reboots then incompletely loads then reboot.... all over again... i already hold the sleep/wake and menu button simultaneously but it does the same i can't use my device
