Here's my problem..when I'm trying to connect my external hard drive via the CCK, it is not showing up in iFile. If I use the SD card reader and pop an SD card in it shows up immediately as a flash drive. Using terminal I typed ls dev and it recognized that the drive is connected and then I manually mounted it to a folder and iFile seen it just fine. Here's what I dont get...I had to do a restore tonight and before I restored, iFile would see the drive immediately after I plugged it in like the SD card. Already tried removing and reinstalling iFile to no avail.
