iOS 6 sound problem
Linnyb
After updating my iPad 2 to iOS 6, my new mail sound appears to be stuck on the choo choo sound no matter what I do to change it. It is set to none currently and the choo choo sound continues. Any suggestions are appreciated!
If you have not already done so, try these:
Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. takes a bit longer than a restart.
Hi and welcome to the Forum!
