ipad1 64 wifi 3g will not activate
I've deleted the second thread you started on this same topic as we only allow one thread for each topic. Multiple threads on the same topic can fragment any resulting conversations, making them hard to follow, as well as being against our rules.
No ideas except it's a hardware problem and go to the apple bar?
It does the restore but will not get past the activation stage.
Its an ipad1 and should'nt need a sim card.
It was working and playing movies fine when this activation problem first started.
Try your luck at ifixit.com but unfortunately I can't see what else it would be.
Genius Bar appointments at an Apple Store are free. They'll be able to tell you what's causing your problem. Unfortunately, given the age of the iPad 1, it won't likely be economical to repair if there is a hardware fault.
