Hello,
I'm playing The Room and I'm stuck in the Orrerary (the level with the planets and planetarium). I've made it to the upper platform; I've decoded two patterns for the little twelve key keypad, but now the clues are indicating a third pattern and telling me I can see it through the panel when I have the eyepiece on. Well I can't. I had paused the game earlier, right after getting the gold medallion, and when I restarted it I think it got ahead of itself and now the clues are out of sync with my position in the game. If that's even possible. Anyway, I can't move forward. Can anybody help? Thanks, Kevin H.
Th
Anyway something seems off
kjhart0133 said:Hello,
Th
Is anyone still playing this game? I'm on Chapter 3 and totally stuck trying to get the light beams to bounce in the right direction I.e through the hole on the left hand side....
Thanks Sandra, still haven't done it, that's the hardest part I've had so far, I'll keep trying.Have you gotten it yet Ivy. Start with the bottom slide.....it only has I think 3 set positions where the light will bounce. So start with that one and try the different positions.
It does it very quick and when you get it, it closes up again. Sorry I can't be of more help.
Just got it, That was tricky.Have you gotten it yet Ivy. Start with the bottom slide.....it only has I think 3 set positions where the light will bounce. So start with that one and try the different positions.
