Battery drain?
Tokkie
the Netherlands
After jailbreaking the iPad 2, it seems the battery is draining much faster than before. Anyone experiencing the same? Can I relate this to SBsetting?
I've been happy with the battery performance since the jb. I expected it to diminish, but it seems every bit as good (or slightly better, if that's possible) then before. It's possible the perception of better is based on how much more I'm enjoying it since the jb.
I just uninstalled SBsetting and will see how it goes. Will keep you posted about this matter.
I'm eagerly awaits Tokkies report! Have noticed a more rapid drainage of battery myself. At least I think so, considering the truthfulness of above post... ;)
I am definitively experiencing a faster battery drain since jailbreaking. I do realize that we are probably playing with are ipads more now and also respringing a lot more. When compared to my jailbroken 3rd gen ipod touch there is a much a faster drain.
Any update on the results for uninstalling sbsettings?
My battery life has seemed to have stabilized now. I guess I was playing around with it a lot and also I have uninstalled the apps I don't use or need.
