twerppoet said:I have a small Vivitar 50-in-1 Card Reader. It works with my 4GB CF cards. YMMV
MikeV99 said:Have you ever tried an USB CF reader and the CC? I saw a video on the Adorama site about the CC and the presenter suggested its use. My CC comes tomorrow and I will give it a whirl.
Is it possible to travel with only the iPad and use it with Dropbox or MobileMe for storage for a lot of raw files over several days. I need to travel as light as possible. If so, can you offer suggestions as to a workflow?
Photosmith looks like it could be a useful tool if it could be incorporated into a Dropbox workflow.
Thanks,
Mike
My cards are larger because my files are fairly large and the Ipad just does not have enough power for either of my CF readers (both Sandisk I think) with the larger cards. Transferring them from my 5D via mini USB cable directly to camera is relatively quick. The SD cards I use with another system upload quite quickly with the CC inserted in the power port.
Diane B said:I did try a CF reader last June when I bought my CC. Neither of mine are self powered and though I was able transfer a few files the first time it quickly threw an error message. I don't have a powered reader but others say they work--most of the time. Its really easy, easier really, to just use the mini USB cable that comes with most cameras and the USB CC. I leave the cable connected to that CC so I don't have to track it down. I've always used a reader but was not going to try and buy a new one when the other option works so well. Just be sure your camera's battery is charged.
twerppoet said:The easiest way is to get an email address associated with your DropBox account and send them that way. You can get one of these at http://sendtodropbox.com/ . The files will show up in the Attachments folder. You'll want to move them for better organization later.
For further convenience you can add the email address to your own contact in Contacts, that way whenever you type your name into an email address bar you will get it as a choice destination.
You can email five pictures at a time this way. Choose the album, tap the edit button, and tap-to-select the five pictures you want to send. You'll have an email button. If you chose more than five the button will grey out.
My raw images may exceed the size allowed by the email server. I will check into it though. Thanks for the suggestion.
