Bennyj99
How do you destroy the fanged frisbee in the store and get to the second level
Hi! did you figure this out? If not, target the frisbee with your wand and blast it. This breaks a box that you will need to build. Ignore the blue diamond thing for right now. Build the box pieces and use the spectroscope to get the glasses. Put them on and head to the right of the staircase. Build both the display stands, the one next to the staircase and the other one is near the front by the duck. For extra money, blast the balloons, and the small brown display stands. The two purple display stands reveal the cauldron, so now you can put the blue diamond in the cauldron. Next, pick up the key in front of the duck and use WiLe to put it into the jack in the box. Next, move closer and use WiLe again to start the jack in the box and wake up the duck. The duck lays an egg, so shoot it to pick up the next potion ingredient, a white piece with a yellow center (probably a flower). Blast the small brown bookcase near the cauldron for the last piece which looks like a red horn. Add that to the cauldron, then swipe the cauldron and give the box of chocolates to Verity, the shop assistant. You then take over Verity so put the key into the lock and hold down the red arrowed lego brick until Verity opens the gate. Head upstairs, don’t worry, you will change from Verity back to your character after you get upstairs.How do you destroy the fanged frisbee in the store and get to the second level
I am also stuck here! Care to share your solution! Please!!
How does one buy characters? I cannot figure it out. Thank you!
Ok, I got the Protego achievement, now I need the one where you have to get the Inferi to attack each other in the cave. Anyone know how to do this?
Go over to the right side of the hole, as close to the bars as you can.
I need some help in Year 6 Chapter 4 'The Cave Entrance' - in the second part of the cave entrance, just before you go down to the swamp there's a Character Token behind some bars and in front of it is a huge hole in the floor. I've gotten the bars blasted by using Petter Pettigrew/ Dolores Umbridge, but I can't figure out how to get to the Token. I've tried using character pets, I've tried blasting the rocks around the hole in the floor, I've tried jumping over (and falling in every time) but, nothing seems to be working! Can anyone help me?
Hate to break it to you but the best bet is to restart the level.
Get past the 3 light door.
Now use Luna or her father to wear spectorspecks. There will be a pile of black rocks right past the 3 light door. It will build this black bird like sculpture. You can explode it with Dark magic but you don't have to. You have to find two more piles of black rocks. If you haven't found them all by the time you should get into the boat you are missing them. One pile is by the lake...but don't jump in the boat because you can't go
You just have to build the three sculptures- that will get you the red brick.
Good luck,
Joy88
