Maasie
Did you ever figure out which character to beat the first brother? The First Brother in the Dueling Club is what I mean.
Did you ever figure it out? I have been stuck for a week and only have 2 of the arrows so I didn't even get as far as you did. How do you get rid of those horn things on the 3rd apparition circle so I can move it? What am I doing wrong or missing? Thanks.
You have to be willing to die a lot. You also have to accept that occasionally Ron will freak out over the spiders. Ron is the only one that can use the sword so he has to run at the whirlwind of Voldemort. Use the wand icon to get him to swing the sword back and forth. Just keep running forward with the thumb button and keep tapping the wand icon. Voldemort will send spiders and sometimes Ron can kill them swinging the sword but sometimes he climbs the sword to hide from them. In that case become Harry and kill the spiders with a reducto charm. Once that is done, run away to the right side, switch back to Ron, hit the block icon to get him to wield the sword again. Start the process again. The main thing is to remember to re-wield the sword after each time Ron dies and swing that thing back and forth as much as you can. It takes forever, but think of it as prep for the endless tapping involved in dueling Voldemort in the last chapters.
Hope that is what you needed.
Joy88
Hi, all.
I and several others have posted a few times that we're stuck getting past the books at Bathilda Bagshot's. We've seen a couple of posts that others have been stuck, and gotten past, but not how they did it. I'm wondering if someone would be so kind as to tell us what the solution was, if you remember?
I simply cannot get by the books. I've checked walk-thoughs, and completed everything they say, but no success. (The walk-through was for a different platform than the iPad, but everything needing done has seemed very similar or identical.)
I'm wondering if I have a bug, but it's far more likely I'm just not seeing/imagining what needs to be done!
Thanks mucho, mates!
Daka
Hi, I seem to be having a lot of problems at the Inferi bit in book six, chapter 4. Basically I can't seem to make the light move from one globe to the other - I can summon it from the first one which gets the Inferi out, but it won't go anywhere. If you're supposed to get rid of the plant on the ladder first, I can't seem to Lumos it away, and it keeps going onto the pink spell but then I can't do anything on the object in the background. If someone could please help, thank you very much!!
In Year 6, chapter 1, at the Wesley shop, it says I should use the glasses to find things but I don't have Luna with me, just Harry. I'm stuck, I found all the ingredient but can't place them anywhere.
You don't have to do anything to do with the window, instead you go to the back of the kitchen and open the door on the left. You then build the bricks to make a stove, which you push as far forward as possible. The stove will open to reveal pink jelly. The flying Santa will drop the black family crest he is holding, which you pick up and attach to the door at the front. You then open that door and continue the rest of the level.
Hi...I did a search and read suggestions and tried...still not working.
I got through all books one time, and am working my way through again to get everything you have to go back for.
I'm in book 5 chapter 2platform 9 3/4. I see that there is a token by that magician's hat looking thing, but even when I switch to Hermione (as suggested in this forum) I can't get it to appear so I can collect it. Can anyone tell me what to do?
Thanks!
