the isn't a door at the back of the room with a white disk on it. The is the door to the corridor and a door the other end to come back - where is the other door?
ktdisney said:So how did you do it? It won't let me break up the silver Lego either
To break silver Lego, you need to have Reducto as your active charm. Hold your finger down on the middle of the screen and it will 'charge' your spell. Move your finger so the circle (I think it should be orange) points at the Lego and it should destroy it![]()
ktdisney said:Thank you for your answer I have been trying this for days. That is what I have been doing but it's not working. I'm in the dark cave (sorry not sure which section). I found one light but can't do anything with it. Near the silver Legos is an area that you need a pet which neither one has. If you keep walking around you can't get pass the fire. Help
. Thank you!!
Could you take a screen shot? Home+lock buttons at the same time. That may help me see where you are.
It's on my iPad so I can't. :-(. I guess it's really not a cave but you can't see where you are walking. You eventually come to a light that does nothing and you walk down and you come upon the silver Legos. The small ones will break but the bigger ones won't.
If you walk around the silver Legos that is where the fire stops you. Thanks. Hopes this helps
I'm stuck at the same place. Did you ever figure out how to move on? I've been trying for several days.It's also the place that you only have Harry and albus Does that help?
Did you ever figure it out? I have been stuck for a week and only have 2 of the arrows so I didn't even get as far as you did. How do you get rid of those horn things on the 3rd apparition circle so I can move it? What am I doing wrong or missing? Thanks.I am still in the cave and can't find the entrance. I read on one of the posts to keep going back and forth getting light. Is there a certain order you have to go because I still only have the same 3 arrows that I began with. I have been doing this for a hour. HELP.
Okay. I'm crying uncle. I have been in this cave for 2 days now. I have gone back and forth with Dumbledore with the deluminator and still can't get any more than 3 arrows. I have to be missing something. Please tell me what I am missing. I would really like to get out of the cave and move on. Any help would be so very much appreciated.
I really am sorry for keep asking but I really can't figure this out. Anyone please help!
