Thank you for your answer I have been trying this for days :-). That is what I have been doing but it's not working. I'm in the dark cave (sorry not sure which section). I found one light but can't do anything with it. Near the silver Legos is an area that you need a pet which neither one has. If you keep walking around you can't get pass the fire. Help :-). Thank you!!
. Harry and albus are the only ones you can use
Can anyone help with this?? Thank you :-)
Gringotts Break In
I can not figure out how to get to the vault, I've made the bike, moved the light and broken the first chain, I've even gotten the trail of coins that is supposed to lead to the vault, but the dragon blows fire and I can't make it out of the circle.
Suggestions welcome please ;)
I'm stuck on 7 part 2 in the room of requirement with the fiendfyre. I am on a ladder going across a river of five, but it is too far to jump. Anyone else gotten past this, and can you offer some help?
You nee to click on the broken circle around the large dot you use to make them move. Press on the part of the circle that corresponds to the position of the arrows that are lit up. You have to use these circles to move around the three locations and take the lights back to light up the three lights around the cave doorway
I got stuck here and Joy88 gave the best instructions. Go to quote #131 and it gives you a step by step. I think it is on page 14. Good luck
Still waiting for help on this.... Anyone? Thanks :-)
Some parts you have to go back to later, in freeplay, when you have other characters. I'm not sure where you are so I can't be more helpful without more idea, sorry :-/
Snowwhitesbow said:
You need to aim at the lamp under the thing that holds the cup through the rocks with the deluminator, light it and the fire will go away and u can hop round and collect the cup.
I don't know if the is the fire part that ktdisney is referring to? :-/
I finally figured out you actually have to PULL the stairs out using the "joy" stick mechanism on the ipad. Good grief, I'd just been standing there waiting for something to happen.
So I'm at the cave I already beat the zombies (at least the first bunch if there are more) now I'm trying to get the spectrespecs but the vine at the top of the ladder won't go away. I've tried walking back and forth in front of the ladder and I tried jumping up but nothing seems to work. Please help?
You have to walk through the big ball of light WHILE the deluminator charm is chosen. The whole cave then lights up and shows you the locations of the lamps and chalices. Hope this helps.
Thank you. I started all over I'm in the half blood prince year 6 chapter 4. Thank you so much for your help. I tried i put the delaminator on and tried to walk through the bit ball of light but nothing happens :-(. Any idea on what Im doing wrong? Thanks again!!
