Parse error after parse error after parse error after parse error after parse error after parse error .........
An ipad forum that doesn't even have an app ??????????????????
How can this be taken seriously ????
Not, I repeat NOT IMPRESSED AT ALL .
Regardless of access via a " browser" ( YUK ) , an app is more appropriate and befitting of the devices this forum discusses , why why why wreck a good thing ?????
The iPad Forum app was made specifically for Forum Foundry's iPad Forums back in January 2011. It accessed the forum software the forum used at the time, vBulletin.
Unfortunately, the developer of the iPad Forum-specific app has not updated it since February 2013 (with the last real update in March 2012). That was way before iOS 7.x, so the app was already not working as well as it could have been.
Now, the owners of this forum have elected to update the forum software. And, this new forum software runs different coding (the forum now uses the forum software called XenForo), so it won't work with the old app. It's like trying to get a Mac to run Microsoft Excel files - you have to get special software ... or update the software you currently own.
For now, there is no update for the "official" iPad Forums app. And, I don't know if an update is being worked on or if another app is in development that will run/interact with the new software.
If using the Safari/web version is not working for you, may I suggest the free Tapatalk app (link:
https://itunes.apple.com/us/app/tapatalk/id307880732?mt=8). I've used it since the start of my time here (about 3 years) and, IMHO, it compares very well to the "old" app. Yes, there are some areas that are different than the old IPF app, but it still appears very similar to me. You will see the same areas you had before - quick access to unread posts, your messages, your profile and various forums. In layout, they almost look the same and have the same interaction.
The best is that Tapatalk can read the new forum software - so you won't hardly notice a difference in your interactions.
I offer any assistance anyone may need in navigating the Tapatalk app. I can start a new thread in the Help section just for Tapatalk questions should anyone wish.
Hope this helps.
